My heat from furnance stopped working
Old 10-23-13, 07:59 AM
B
I am having the same problems.
http://www.doityourself.com/forum/ga...ing-g43uf.html
However, we are purposefully letting our propane run out before we switch to natural gas. We are at about 15% full on propane tank. Any chance the lack of pressure in our tank would affect the furnace this way? We have enough gas for our stop top, though I know this takes a lot less pressure.
Old 10-23-13, 08:09 AM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Moved to own thread................
Old 10-23-13, 08:23 AM
Received 4,049 Upvotes on 3,632 Posts
Absolutely. It takes pressure as well as volume. Put a stove top burner on and then try the furnace. If you see the stove burner react then you've confirmed a propane issue.
