No heat - gas furnace - pilot is lit
Old 10-26-13, 10:19 AM
R
Received 2 Upvotes on 2 Posts
I have a Nordyne propane furnace and heat pump.
The pilot is lit but the burner won't ignite (set point is more than 6 degrees higher than indoor temp).
Emergency heat does not ignite burner.
Blower appears to be doing what it should.
Heat pump is working intermittently. It will run for a long time (60 minutes+?), but then shuts off for a period - perhaps 15 minutes or more(?).
Outside temp is now 50F and was 30F overnight.
Can anyone offer troubleshooting steps, please?
Old 10-26-13, 01:37 PM
R
Resolved:
I found that one of the transformers was bad.
