NORDYNE gas furnace that is not working.
Old 10-27-13, 10:13 AM
B
can you please help me. I have a NORDYNE gas furnace that is not working. I believe the model number is (M1GH 070A AW)It will not turn on at all the standing pilot is on, but the fan nor the heat will turn on. the air conditioner will not work either. I am desperate please help. I have replaced the thermostat and the wires to it that go to the heater. I don't know what to do next, and its getting cold.
Old 10-27-13, 12:32 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
http://www.nordyne.com/Literature/690a.pdf
Did the problem start before or after you replaced the stat?
If the low voltage fuse is good, jump R to G at the furnace to see if the fan will run. Be sure that the furnace door switch is depressed.
