Carrier Weathermaker 58SXC furnace won't ignite
Old 10-29-13, 06:58 PM
G
I just turned on the thermostat for the season. There was no hot air blowing out.
I turned the switch down and turn back on. The furnace was cycling and the the ignitor was cherry red. Gas valve is in on position but the furnace won't fire up.
What to try next? how do I make sure the gas valve is working properly?
Old 10-29-13, 07:17 PM
Houston204's Avatar
Received 94 Upvotes on 87 Posts
Measure for 24VAC between blue and brown at the gas valve after your ignitor glows.
Does the ignitor continue to glow indefinitely or does it power down after ~45 seconds?
Old 10-29-13, 08:19 PM
G
is it DC on the ohm meter?
I think it is 0 volt
It lights up and then shuts down after about a minute or so. sometimes it lights up more and then dims, and then lights up again.
BTW, Are the 2 plugs under "C" the same? I might have mixed them up.
Old 10-30-13, 06:14 PM
Houston204's Avatar
It's AC volts. Wiring looks ok.
Measure between P and C for 24VAC when the ignitor is glowing.
Old 10-30-13, 08:29 PM
G
i did using the ohm meter on AC dial. I got .01 V
What does that mean? What do I need to change? can I handle it myself or I need an electrician?
