Troubleshooting a coleman gas furnace
Old 10-31-13, 06:44 PM
D
I have a coleman gas furnace and everytime I try to start it up it blows the 3amp fuse..can I troubleshoot it? And if so, how can I?
Old 10-31-13, 06:56 PM
Received 3,978 Upvotes on 3,570 Posts
Welcome to the forums.
A model number would be a good start.
Also....when does the fuse blow exactly ......when you turn on fan, heat, A/C ??
Old 10-31-13, 07:22 PM
D
The model number is DG AA077BDTA.and it blows the fused as soon as the power is turned on, .
Old 11-01-13, 01:41 AM
Some models appear to have a 3A fuse in the transformer to R connection.
You can try removing the R thermostat wire from the furnace and see if it stills blows fuses.
Your service manual:
download/list_pdf/INSTL/L0611386.pdf
