Connecting to control board
Old 11-05-13, 02:06 PM
I'm trying to connect the my humidifier to the control board. My Lennox g60uh(X) has "HUM" prongs but I couldn't find anything at the home centers that connect to those prongs. What gauge wire should I use to connect to the transformer?
Old 11-05-13, 02:50 PM
firedawgsatx's Avatar
Received 2 Upvotes on 2 Posts
14 gauge stranded wire with 1/4" terminals will work if you are connecting to the 120V HUM terminal.
Old 11-05-13, 02:53 PM
Can I just connect to the "W" and "C" directly even though the thermostat is connected to those wires as well? That way I don't have to bother with the extra transformer?
Old 11-05-13, 03:04 PM
The HUM terminal on the control board is 120V. You would have to refer to your humidifier installation
instructions to determine how to properly wire it.
Old 11-05-13, 03:14 PM
My humidistat is 24v. My humidifier was wired incorrectly before. It was connected to a transformer that was connected to the junction box that powers the furnace. It was on all the time. I only want it open the solenoid when the furnace is blowing heat.
I was hoping to skip wiring the "HUM" 120 terminal to a transformer and wire the humidistat to the same terminals that connect to the thermostat.
Old 11-05-13, 03:43 PM
If you post the model number of your humidifier I am sure someone here will be able to assist you. I suggest you post in the humidifier section to get better results.
