Janitrol GAS furnace with AC
Old 11-14-13, 12:00 PM
R
Hello I am new to your forum. I just purchased a home in the mountains of NC. And we are having issues with the Janitrol GAS system. The thermostat is set to 80 but yet it is 60 or so in the house. Replaced the thermostat with a TH3110D and having the same issues. It cycles but does not get to temp or any where close.
Does anyone have anything else I can do to test. As it is getting cold her with temps in the teens at night. I would like to get this working properly if possible.
Thanks in advance for your replys.
Old 11-14-13, 05:31 PM
Received 4,046 Upvotes on 3,630 Posts
Welcome to the forums.
Did you check and see if the burner is lighting ?
Try to post a model number so we know what you have there.
Usually the ID plate/tag is behind the front access panel.
