Lennox Gas Fireplace wont stay lit!
Old 11-14-13, 04:02 PM
I have a Lennox natural gas fireplace. It is a model number VF400cm-2 installed when our house was built in 2007. I usually cut of the gas and pilot each spring when the unit isnt needed anymore and then relight it in the winter months. This year I was able to relight the pilot like normal but when I turn the control knob to the "on" position the flame keeps going out. I can relight the pilot again in the pilot position but as soon as I turn it to "on" ... same thing? I was told it was probably a thermocoupler but on this particular unit the coupler and pilot come together as an assembly (pn# h4114) which the parts store says is about $170.00. Just looking for some confirmation from others before spending the money and throwing parts at it?
Old 11-14-13, 04:34 PM
Received 4,050 Upvotes on 3,633 Posts
I can't seem to find a VF400 in the product list. Are you sure it's not VF4000-CMN-2 ?
Old 11-18-13, 02:49 PM
yes, VF4000-cmn-2. I left off a zero accidentally.
Old 11-18-13, 03:11 PM
user 10's Avatar
Received 57 Upvotes on 50 Posts
If the pilot stays on with the button released but in the pilot position, the thermocouple is good.
Try leaving it in that position for a few hours to see if it stays on.
A dirty orifice can cause the pilot to go out, so don't change the thermocouple until you're sure that it's bad.
