Carrier Control Board Help
Old 11-16-13, 06:23 AM
T
Thumbs down Carrier Control Board Help
My thermostat display is out(blank) and my blower is on continuously(cold air no flame). i checked voltage at the thermostat and it was 13vac. same at the output of the control board. the voltage at the sec windings of the transformer is 24v. does this mean my circuit control board is bad? Error code 33 turns to 13 after a few minutes
The thermostat display was intermittent for a few days.
Old 11-16-13, 08:58 AM
Received 3,485 Upvotes on 3,128 Posts
Welcome to the forums.
A model number of the furnace would be helpful.
Usually what happens is if you have a defective or open safety sensor...... the blower will run to let you know there is a problem.
Plenum overheat is a trouble 33
Flame rollout is a trouble code 13
Old 11-18-13, 11:12 AM
T
the circuit control board is CEPL130438-01. I dont know the furnace model offhand will check a little later. thanks for the welcome.
