My gas boiler has a pilot light but will not fire. Help!!!
Old 11-21-13, 05:52 AM
P
Hi Guys,
My gas boiler is not firing up!!! It was working fine up until this morning.
I have a UTICA MGB150HD Gas Boiler with a HONEYWELL VR8200A Gas Valve and a FIELD CONTROLS GVD-4 exhaust damper.
The boiler has a good pilot light that is currently working.
The thermostat is working because I can see the aquastat click on and I can hear/feel the circulation pump kick on as well.
Water pressure is at 15 psi
Any help getting this boiler to fire up would be great!
Pat
Old 11-25-13, 05:03 AM
P
I figured it out and it turns out that it was a defective exhaust damper.
Old 11-25-13, 05:53 AM
lawrosa's Avatar
Super Moderator
Received 84 Upvotes on 76 Posts
Good job... I assume you switched the damper to manually open.....
Sorry we missed your original post....
