Gas miller forced hot air help plz
Old 11-25-13, 12:19 PM
Ok guys this is what I am having problems with I have a mobile home stand up miller gas furnace I replaced the themolcouple cos the pilot light wouldn't stay litiit then this just started after I did that I got the pilot light stays lit now but when it fires up its like it's blowing the flame and it makes a bunch of noise now could the gas tube have a leak now is that what is causing my problems idk but any help would be great
Old 11-25-13, 06:19 PM
Received 3,980 Upvotes on 3,572 Posts
The noise starts when the main burner lights.... correct ?
It sounds like the burner tube may be dirty..... possibly rusted on the inside.
You could have a partially plugged orifice. That's the little brass nut like nozzle where the gas comes out.
Old 11-26-13, 03:52 AM
Yes only when the main burner lights it starts out making noise and then after a while it will quite but I have replaced my burner gas tube replaced the nozzle and banged the burner tube out and now it works great thank you bud
