No heat, due to space heater valves?
Old 11-26-13, 04:18 PM
B
I recently moved to a condo and seem to be experiencing an issue with the heater.
Problem: "cool" air comes out of the vent when heater turned on.
Source: Gas water heater
I was told by a neighbor that I may need to turn or open a valve on the water boiler. On the water boiler itself, I noticed two pipes, one for service heater inlet and one for outlet. The valve for outlet is off, and inlet is on. Do I need to then just open the valve for outlet? I've included a picture of what I'm exactly speaking of.
Any help would be appreciated!
Old 11-26-13, 04:27 PM
Received 1 Upvote on 1 Post
Open it and see, bet you'll have heat in a few seconds.
