Siegler floor space heater problem
Old 12-02-13, 03:57 PM
L
I have a Siegler floor space heater that I am having trouble with. When I start it up it gives off a smell of gas. All the connections are fine, no leaks. Are there any other parts I can inspect and possibly replace myself? Of course the heater is off now, but I would really like to start using it so I am trying to narrow down the issue and trying to take care of it myself. Any help would be greatly appreciated.
Could a clogged burner cause it? It seems to light up fine but the smell is still there.
Thanks in advance for any help,
Luis S.
Old 12-02-13, 04:20 PM
Received 3,415 Upvotes on 3,063 Posts
Welcome to the forums.
Wow....I haven't see one of those around in awhile. They were big in the mid to late 50's.
Is yours a natural gas model with a pilot you have to light ?
Does yours have a thermostat or outside vent ?
Old 12-02-13, 04:46 PM
L
Thanks for the welcome, yes it is an old one, but was working great until I tried lighting this year. I need to light the pilot myself and it does not have a thermostat.
Here is a picture of the heater, unfortunately this is the only one I have right now.
Luis S.
Old 12-03-13, 01:20 PM
Received 3 Upvotes on 3 Posts
How did you determine there were no leaks? Did you use soap solution on fitting?
