Gas Valve on/off switch
Old 12-05-13, 10:35 PM
Hello, I just moved into a house and in the garage I noticed a gas line attached to a heater. Normally I know that if the valve is running perpendicular to the pipe it's in the of postion. I just wanted to double check.
I flipped the switch both ways I didn't hear any change nor do I smell a difference really... but it might take time to get an ordor.
On right? This is how it was when we moved in,
Off right? I'm assuming this is off... right? Or can a switch like this be installed backwards?
Thanks in advance.
Old 12-05-13, 10:55 PM
lawrosa's Avatar
Super Moderator
Received 84 Upvotes on 76 Posts
Hi and welcome.........
Yes you are correct regarding the on and off of the gas valve....................
Old 12-07-13, 08:02 AM
Thanks Lawrosa! Confirming it makes me leave my mind at ease.
Old 12-07-13, 08:06 AM
Norm201's Avatar
Received 716 Upvotes on 637 Posts
I don't think it can, but you might try taking that handle off and see if it can be re-attached in either direction. If your not sure or if you think the previous own er might have done it.
