How to beautify a Monterey Home furnace?
Old 12-07-13, 10:59 PM
Hi, I live in a small apartment with a 1990s style Monterey Home furnace, by Williams company.
[ATTACH=CONFIG]22619[/ATTACH]
My problem is the thing is ugly and full of dust. I try and keep it clean, but soon enough it's dirty again. I'd like to frame a wall around it and put some kind of metal screen for the heat to pass through, do you guys think this is a safe and efficient idea?
I'm also open other ideas… to make this beast less ugly.
Thank you!
Old 12-08-13, 02:37 AM
Received 3,897 Upvotes on 3,494 Posts
Welcome to the forums.
There isn't too much you can do with that unit. It is what it is.
I'm not sure how a metal screen in front of it wont get dusty like the unit gets now ?
Old 12-08-13, 09:29 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Only the bottom panel collects dust, so if you have a good filter in place the top half should remain reasonably clean. Replace the filter every 30 days. I would not alter the furnace at all, unless you wanted to replace it.
Old 12-08-13, 01:44 PM
Received 3 Upvotes on 3 Posts
Where would you install a filter on this unit?
Old 12-08-13, 06:10 PM
G
Measure the intake vent and see if you can buy a filter about that size. Place the filter over the intake and secure with a strong tape. Maybe metal tape. You might be able to rig something with magnets.
Old 12-08-13, 06:30 PM
I don't think I would advise this, I'm sure the dust he speaks of is on the entire panel. Remember this is not a counterflo with a blower.
Old 12-09-13, 08:39 AM
Thanks guys.
The front panel opens, so I will check and see about a filter. I have lived in this apartment almost two years, and nobody has changed the filter to my knowledge.
Also, I think the front panels can be removed, so I might do that and wash thoroughly. Maybe if I do this and actually maintain, it will look cleaner?
Old 12-09-13, 04:40 PM
This furnace is not designed to accept a filter.
Old 12-09-13, 04:55 PM
Do you have any maintenance suggestions?
Old 12-10-13, 10:24 AM
Remove the cover and wash it. You might call your gas co and have them check it out. They will clean the pilot and burner if needed I suspect. The danger with removing the cover is leaving a hot heat exchanger exposed to someone who may accidentally touch it before you replace the cover.
