Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Gas and Oil Home Heating Furnaces
Reload this Page >
Day & Night Gas Furnace turns on and off twice after completing heating cycle
Old 12-08-13, 09:58 AM
I have a Day & Night gas furnace. It heats the house fine but after a heating cycle is complete and the fan shuts off, the fan will start up for a second then shut down and a couple seconds later it will do it again. This seems to be more of an irritation than anything but could this be a warning of future problems?
I tried changing batteries in the thermostat and the limit switch with no change in operation.
Any ideas?
Old 12-08-13, 10:09 AM
Received 3,897 Upvotes on 3,494 Posts
Welcome to the forums.
That's not an un-common problem. It happens when there is extra heat left in the heat exchanger.
It's not controlled by the thermostat but by a limit switch.
You mention limit switch.... is it an adjustable one for the blower ?
Old 12-08-13, 10:17 AM
Thanks for the reply PJ.
The switch I changed is installed just above the burner inside the heat exchanger. Its a non-adjustable 180 140 degree switch, it turns on the fan at 180 and shuts it off at 140.
Old 12-08-13, 01:50 PM
Received 3 Upvotes on 3 Posts
PJmax meant to say fan switch. Sounds like you changed the limit. If this old enough to have a fan switch and not a fan timer board, I believe it probably has a Camstat fan switch. Look for it close to the limit. If it does have this it will have a red face as I recall and it is adjustable. However those were known to short cycle after they became old. This happens mostly on counterflo models
Old 12-08-13, 01:53 PM
His unit doesn't have an adjustable fan control. It's a preset control that looks like a limit switch (clixon)
Old 12-08-13, 03:01 PM
The only fan control I've noticed beyond the limit switch is a terminal board used to adjust the fan speed. A sticker on the lower access panel mentions three speeds and moving a wire accomplishes this task.
