no heat from Trane XR90 7 years old
Hi, we have a Trane XR90 that currently is not blowing heat. the red light indicator is flashing 9 times which means it is the ignitor. So I researched the panel and found the HSI but I havent clearly found it on the furnace. I did open the metal box area and see where the flames from the gas would be, the flame sensor, and then a metal popsicle stick looking part that can be disconnected. Is that the ignitor? Please help single mom of 3 kids no heat and just bought christmas gifts so I have to fix this myself. Thank you.
I added a photo, the small circle you see is where the flame sensor is and the other part I was thinking is the ignitor. I can take another photo. I took that metal plate off. I did try removing the double wired part that goes right below that metal area, but when I pulled it out there is like a rubber coating over the inside part and I am unable to get it completely out of the space.
thanks for reading and hope you can help.
