duomatic Olsen ultramax furnace troubleshoot
My furnace has had a few issues with start up. furnace does not start up automatically,but if turned off manually and then turned back on will run. Whats wrong?
Received 39 Upvotes
When you turn it off then back on you are probably resetting the control. Before doing so again look for a blinking light. Sometimes there's a view port in the blower compartment door thru which you can see the light. Count the blinks then check inside the blower door for a key to the blink code.
