Honeywell RA117A Stack relay
I recently replaced the stack relay on my hot air furnace. I tested the oil gun by plugging into 110 volts,it ran. I tested the transformer,got about a 1 inch arc. The blower motor also works. The old relay failed so I changed it out,it worked fine for a few days,then the furnace kept running after the temp set on the thermostat was reached. The lower contact bar on the top contacts stuck (welded) closed. I believe this was the problem that caused the failure of the old relay,because the same bar was blue,like it had overheated. What would this indicate as a problem? What does the top set of contacts control? I killed the power to the furnace and pulled the contact open with a small screwdriver. I think it is OK because it came apart fairly easily,but I don't want to burn out the new relay using it. I need to fix what is causing the problem.
Next time you think it's over shooting the t-stat, from the 117 remove 1 of the t-stat wires and see if the burner stops. If it does it could be you stat. If it continues to run with wire off it's the stack relay.
Received 38 Upvotes
In my opinion the best thing you could do is to take that ancient technology stack switch and drop-kick it into the next county. Stack switches are notorious for failing. Instead have a cad-cell primary installed, far, far safer than that stack switch.
