Honeywell zone valves
Old 01-05-14, 09:10 PM
T
I have two zones for heat both have Honeywell zone valves. When I turn my thermostats to call for heat neither valve is working? Any help is appreciated
Old 01-05-14, 09:13 PM
lawrosa's Avatar
Super Moderator
Received 84 Upvotes on 76 Posts
Sounds like the transformer went bad.... Test the transformer that powers the zone valves and see if there is 24v at the terminals...
Old 01-06-14, 09:52 AM
T
Thank you Lawrosa that was it appreciate your help. That's one problem solved. You know anything about wood furnaces?
