beckett oil burner
beckett oil burner
My beckett oil furnace fires up right away but after running threw the whole cycle it resets.. I am noticing that the electrodes are constantly setting a spark off from the transformer, causing everything to get hot.. How can i stop this problem.. thanks
Received 38 Upvotes
That would be running through the whole cycle, not threw.
Please elaborate on what you mean by the whole cycle. What kind of primary control (manufacturer and model number) is controlling this burner? What do you mean when you state it resets? Do you have to manually push any reset buttons and if so where are these reset buttons?
