Goodman furnace model gmpo 75-3
I have the above furnace that would not light, I found that the Hot surface ignitor was burnt out . I checked out the whole sustem ( heat exchanger0 ECT. FOR ANY PROBLEMS I checked the voltahe cycling to the igniter and it was 119.5 volts on then.05 off. I manually lit the furnace and it worked correctly. Purchased a new igniter (p/n B 1401018 s) and installed the part. fired up the unit and the igniter glowed so hot that it broke ( again) any suggestions ??
I heard these things are extremely fragile, and not to be touched on the ceramic part at all.
Did it get bumped at all while positioning it to install it, or did you maybe touch it during installation? Will have to wait to see if a pro can comment on if this is something that happens once in a while with HSI's. Possibly a defect in it from manufacture.
Welcome to the forums.
It may have gotten cracked when installed. They are extremely fragile.
Yes..... I have broken some while installing them.
Received 39 Upvotes
Since that furnace uses a separate flame sensor, you can go to a Silicon-Nitride ignitor instead of the Silicon-Carbide originally installed. The nitride ignitors are FAR more durable than the carbide ones. Here's some information fro Honeywell:
Honeywell Glowfly™ Universal Hot Surface Igniter - Honeywell ForwardThinking
The only time I install a carbide ignitor is if the furnace uses the ignitor to prove flame. Most of that type systen will not work with a nitride ignitor.
