Need help wiring thermostat on boiler...
I have WeilMcLain cgm-6-pi boiler. I currently have a honeywell programmable thermostat which has 2 wires connected and is working fine. I want to install a wifi thermostat which requires a C wire. Since i have to run a new cable anyways and it would be really hard to do so in the current location of the thermostat i figured i run a brand new wire directly from thermostat (in new location) to the boiler. Can anyone please help me with wiring it on the boiler itself? I am attaching couple of photos. I am also attaching photo of the gauge on the boiler if you can tell me if its correct psi and stuff. Thanks in advance for any help.
Received 41 Upvotes
That appears to be all factory wiring. You could attach the common to the terminal marked "C" on the transformer pictured. Connect the red & white to where the existing thermostat wires are attached.
For a single story house & cold boiler the pressure looks fine.
