Furnace Common Wire Question
I've purchased a Honeywell Wifi thermostat that requires use of a "C" wire. The issue is that I currently do not have "C" wire but I do have one available wire that's currently not in use (wrapped around the base of the wire on both ends). My question is...I currently have a wire connected to the "C" terminal on the furnace end. Can I add this available wire to the "C" terminal even though there is one currently there. I've attached a picture for further reference.
Wiring
Thanks.
Wiring
Thanks.
Ok, so just to make sure I understand what you're saying... even though there is a wire connected to the C terminal, I can add an additional "C" wire going to my thermostat because it will still remain 24v?
Yes, connect the unused stat wire to the furnace C terminal along with the red wire currently there.
