Goodman GMP No power to hot surface ignitor.
Old 02-13-14, 02:04 PM
No power coming from terminal on the control board to hot surface ignitor.. Replaced the board everything was ok. few days later same thing again? if I plug it into another terminal it works so i know it is good. Any help?/ Maybe wires crossed shorting it out?
Old 02-13-14, 03:24 PM
Grady's Avatar
If the pressure switch isn't closing, you won't get any power out of the ignitor terminals.
Old 02-14-14, 07:26 AM
No power to control board ignighter
I tok a board out of a working unit. Hooked it up to the one that was not getting power to the ignighter before. It worked fine then a few days cut off yan same problem. I take the board that i got out of the working unit and hook it back up to the unit that had no problems and it the same. So now i have 2 boards that willbnot get power to ignighter. If i take the ignighter and move to another slot it will come on. Any help.
Old 02-14-14, 07:59 AM
Upvotes Received: 214
Did you verify that the pressure switch is closing on a pre-purge ?
