Amana aircommand 95 will not come on
Old 02-21-14, 12:33 PM
I have an amana furnace that worked fine yesterday and will do nothing today. All info I find says refer to the LED light on control module to determine fault. My light is off and the only course of action suggested is the power is disconnected. Not the case. I have power through the door switch and at the module but still no light and no furnace functions? Nothing runs, its like it is not even hooked up? Help.
Mike
Old 02-21-14, 08:57 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Look on the circuit board on which the LED is mounted. You should find an automotive type fuse of either 3 or 5 amps. Pull the fuse & look at it to see if it is blown.
