What's this? And what should it be set on?
Old 02-25-14, 01:52 PM
B
What's this? And what should it be set on? Thanks Name:  image.jpg
Old 02-25-14, 02:02 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
Apparantly to adjust temperature of course...
But need more info..
Whats the make and model of the unit its on?
What are you trying to do?
Old 02-25-14, 02:11 PM
B
Well, it's a Honeywell. I don't know the make and model. I want to know what it should be set on? Should I push it to Auto, Fan or Man?
Old 02-25-14, 02:18 PM
lawrosa's Avatar
Super Moderator
Its on a air handler?
I dont know what to set it for... We need more info.
Old 02-25-14, 02:39 PM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
Limit switch? Do you have gas or oil heat?
Old 02-25-14, 02:50 PM
B
airman.1994, I have a gas furnace.
Old 02-25-14, 02:55 PM
B
Lawrosa, I have a Goodman GMT115-5 Furnace. It is 115,000 BTU's. This is connected to where the A/C coil is. If you take it out, it has a long metal rod that goes into the A/C coil. So I don't know if it is set right?
Old 02-25-14, 05:27 PM
B
I did some research and it is an old Honeywell limit switch. I just can't figure out if it is on the right setting. You know how it has the small switch in front of it. It says Man, Fan and Auto. It seems to be pushed on Auto. So should I have it on a different setting? Is it on the right setting?
Old 02-26-14, 03:28 AM
F
The three "tabs" are the settings for safety shutdown (200), blower start (150) and blower stop (100). I think all three are set a bit high and I would rather see them at 190, 130 and 80 or 90. The Auto-Fan-Man switch is to run the blower manually and should normally be left in the auto position.
Are you SURE this control is even in use? Most furnaces built in the last thirty years have this control function built in to the furnace proper. Is there a conduit and/or wires going to the control? Can you remove the cover to see if there are any connected wires? Does the blower run if you switch it to Man?
Old 02-26-14, 09:58 PM
Received 3,750 Upvotes on 3,362 Posts
That's definitely not part of that furnace. The Goodman GMT's blower is controlled from the main control board. That limit switch may have been from a previous furnace and just left there.
Old 02-27-14, 12:30 PM
thanks guys sorry i could not get back in time.
