Changed Blower motor on Furnace new motor does blowout heat like old one.
Old 02-25-14, 06:02 PM
N
Hello everyone,
I have an older furnace, a 1980 Williamson Gas Saver II model. I have been in the house 7 yrs and never had a problem with it, changed filters and performed regular maintenance on it. Last week I woke up to a glue/burning smell coming from the registers. Went downstairs, blower motor was red hot and the furnace would shut off. This is not a direct drive blower and the old motor was a Dayton #5k918c 1/3 hp 6.8 amps.
Got new motor, a century motor from a local motor shop model # GF2034, 6.6 amps, hook it up was working fine but notice after 5-10 minutes the furnace kick off. Looked at the fan & limit switch and the limit switch was tripping. Usually that means furnace is not getting enough return air. I double checked everything and swap filters but it kept doing the same thing. I hook the old motor up everything fired up and ran till the motor got hot again.
I was convinced the century motor did have enough power in it. I spoke with grainger tech support, of course my old motor was no longer made but I spoke of my problem and he mentioned to get a 1/2hp for better rpms. Model # 6k589 1/2 hp 7.6 amps. So being confident , I installed this motor and bam same thing happens, limit switch is getting tripped and then furnace recycles.
I again hook up old motor and everything runs fine until it overheats. What am I missing here. It seem like a simple motor replacement issue ? Any help would be great here as I am on space heater mode until fixed. Thanks!
Old 02-25-14, 09:25 PM
Received 4,046 Upvotes on 3,630 Posts
Welcome to the forums.
Whether it's 1/3hp or 1/2hp....... RPM's are RPM's.
How about direction ? The blower wheels are only effective turning the forward direction.
Old 02-25-14, 09:31 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
I do not like getting a replacement motor with a lower amp rating. but...
Did you check the motor rotation?
The Dayton belt drive motors that I get from Grainger are reversible.
You are too fast for me PJ
