Gas issues on a Carrier58SXC060-GG
Old 02-27-14, 05:24 AM
D
For the past couple of weeks my furnance is having issues from time to time, but now more ferquientily. It will run through a heating cycle completely but then when it goes to start up again the gas will not turn on, I have watched and listened to it and the inducer motor kicks in and I can hear the pressure switch click and the ignitor will glow but no gas is relaesed, it will thne run through 3 cycles trying to light and after that the main blower kicks on and blows cold air. If I turn off the thermostat for a minute or two and then turn it back on it light up and run for three or four cycles just fine and then act up again. I have no idea what to look for or check please help....
Old 02-27-14, 09:20 AM
Check to see if it is getting 24V to the gas valve when it is trying to start. No 24V your module could be bad. If it gets 24V the valve might be bad.
