Igniter and Flame sense rod materials
Old 03-11-14, 09:08 AM
Is there any difference between the material used in a typical igniter electrode and a flame sense electrode?
I am asking because we have a one-of-a-kind oven that has a fenwal ignition module with a single spark and flame sense set up. The igniter electrodes that I can find are just a little short and I always end up with a "fragile" installation on the flame sense side.
I have found a longer flame sense electrode that I should be much better able to position and can ground to the burner body for the spark. I am assuming this would work find but just want to check. The electrode and flame sense products are both made by Fenwal.
Thanks,
Old 03-11-14, 08:18 PM
Received 3,750 Upvotes on 3,362 Posts
This is posted in the gas and oil home heating furnace forum.
Is this used in a cooking oven ?
Old 03-11-14, 08:37 PM
Flame Sense rod material
It is a commercial oven - but the parts used in it are more like those found in gas furnaces - hence the post here.
