Furnace not igniting
Old 03-25-14, 08:10 AM
Have a fg6ra-072c-12a gas furnace . Code light flashes for times suggesting ignition failure. Inducer fan comes on, here a click for hsi to heat up but does not glow. Then gas comes on but shuts down. Any ideas as to the problem?
Old 03-25-14, 08:15 AM
Received 3,740 Upvotes on 3,356 Posts
Welcome to the forums.
You'll need to check the igniter. It needs to be checked for continuity. You can visually check it but it can be hard to see some cracks.
Old 03-25-14, 08:36 AM
Used a meter and igniter toned for continuity
Old 03-25-14, 09:11 AM
The next step would be to check for approx 120vac to the igniter.
The link to your manual is below. A good step by step diagnostic routine.
http://www.nordyne.com/Literature/708291b.pdf
Old 03-25-14, 10:01 AM
If i am not getting 120 v from the ignitor terminals when it is calling could the board be bad?
Old 03-25-14, 08:23 PM
Yes.... it could be a defective board. It could be a connection to the board too.
