Any Special Tool For Compressing The Spring Arms on Board Retainer Pins?
Don't know about other boards, but on mobile home furnaces I've seen, there are white plastic pins (mounting pins/post is probably a better word) that the board snaps over and onto. These posts have small spring arms that collapse into the hollow body of the post when putting the board on/over them, then as the board snaps on to the post, the spring arms expand to hold the board in place.
To remove the board:
Since I posted this, I discovered a video in which the host uses a BIC pen, after removing the guts of the pen. So then you have a hollow tube to push over the small white plastic posts - it compresses the small spring arms into the hollow body of the post, as you simultaneously pull gingerly on that corner of the board. Worked very well in the video:
https://www.youtube.com/watch?v=FFx3-3ChT58
So my question has been answered, but happy to hear other methods, if anyone would like to jump in.
Ok... gotcha. Locking circuit board standoffs
There isn't a tool to release them, that I know of, other than needle nose pliers.
The pen barrel is a great idea.
Received 39 Upvotes
There is a tool available at Radio Shack & other electronics stores with is intended for use on Molex plugs but works very well on those plastic clips. I've also used a piece of copper tubing (1/4"?).
