air filter
Old 04-05-14, 07:42 PM
B
air filter
Is this slot where my air filter goes?
imgur: the simple image sharer
I haven't had a filter on for well over a year. Is it possible to see if this has caused any excessive dirt/dust accumulation? I have a 80% Goodman gas furnace.
There's also an 18x18 air return grille on the furnace utility closet. Does that need a filter too? Or would that just filter the air twice?
Old 04-05-14, 08:26 PM
user 10's Avatar
Received 51 Upvotes on 45 Posts
You only need one filter, preferably at the furnace.
The blower wheel and a/c coil are probably plugged with dust.
It might be possible to get the coil cleaned in place, but if it has to be pulled, you're looking at a few hundred dollars.
Old 04-06-14, 04:08 PM
Grady's Avatar
Received 39 Upvotes on 37 Posts
The slot shown in the picture would only be a filter rack if the furnace were a downflow model. If the blower is in the top of the furnace it would be a downflow model. My guess is the one in the closet is for combustion air.
Old 04-06-14, 04:42 PM
user 10's Avatar
When the fan is running, does air blow out of the slot? If not, it's for a filter.
Either way, there has to be a filter in the system.
Old 04-06-14, 05:44 PM
B
I have a slab foundation and the majority of the registers in the house are in the slab. Does that mean it's downflow?
Old 04-06-14, 05:45 PM
G
Received 2 Upvotes on 2 Posts
There should also be a sheet metal top strap to seal (at least partially) the opening after the filter is installed.
Old 04-06-14, 05:58 PM
Grady's Avatar
Botbot,
Turn the furnace on & once the blower comes on, hold a tissue in front of that slot. If the tissue is drawn in, the furnace is a downflow & the slot is probably where the filter should go. On the other hand, if the tissue is blown away from the slot, the furnace is an upflow & the slot is NOT where you should install the filter.
Old 04-08-14, 02:21 PM
user 10's Avatar
With registers in the slab I have no doubt that your furnace is a downflow.
It'll definitely need to be serviced after running without a filter - don't just throw a filter in there and call it done.
