Aquasmart 7600 Lockout: Sensor ERR
Hi All,
Just bought my first house last year (in Nassau County, NY) and came home the other day and there was no hot water. Went to the boiler and saw that the Beckett Aquasmart shows "Lockout: Sensor Err" and toggles to "Freeze Res: WTR:--F". It is my first time dealing with an oil boiler (have always lived in a house with gas run boilers). From everything I've read, it seems like the temperature sensor is shot. It isn't passing the self check process.Just wanted to know if it is an easy swap. It seem I just need to make sure power is off, undo the screw the screw on the side of the Aquasmart, unplug the RJ45 type jack, unscrew the ground screw and pull out the sensor from the immersion well. Is that correct? Just a little frustrated since this is a new boiler/system. It was put around 2011/2012 (as per the previous homeowner). Can this be done as a DIY by a novice or should I just pay for an HVAC professional to come take care of it?
Thanks for any input.
1. In which area you live and ambient temperatures you usually experience.
-Northeast, Long Island, NY
2. House style and construction details.
-Brick/Shingle Cape
3. Make, model and age of equipment related to the problem.
-Burnham V8H (model# 101341-04 manufactured 05/2011) with Beckett Aquasmart 7600 boiler controler
4. Fuel type.
- Oil
5. Water temperature and pressures of boiler systems.
- zero. locked out and no temp or pressure
6. What type of zoning do you have with your boiler system.
- 3 zone baseboard heat
7. Thermostat type.
- 3 Lux 7 day programable, touch screen
7. Anything else that would be useful. No detail is to small. The more information you provide the easier it becomes for the professionals in this forum to determined the cause and correction to the problem.
-Brick/Shingle Cape
4. Fuel type.
- Oil
7. Thermostat type.
Received 39 Upvotes
Replacing the sensor shouldn't be a big deal. Here's the manual on the Aquasmart:
http://www.beckettcorp.com/protect/manuals/61738.pdf
