robertshaw 780-715
Old 04-27-14, 02:08 AM
Question robertshaw 780-715
Hi, I have a robertshaw 780-715 but cannot seem to find what "va" is needed for that board.
Currently I have been running 120v primary to 24v secondary at 40va.
Is this correct or can I step it up to a 50va ?
Old 04-27-14, 04:00 AM
Welcome to the forums.
Why do you need to increase the transformer size ?
40va is plenty to run that board and it's connected components.
Old 04-28-14, 01:51 PM
Thanks for the reply
I had read the manual for the 780-715 but i could not find a amperage rating anywhere, the original transformer was a 40 amp, and was not sure if the amperage was correct.
The transformers keep burning out after a short while of use, has to be a short somewhere along the line.
Im still unsure how to wire the flue motor, I will take some pictures and post them later with more detail.
Any input will be greatly appreciated.
Thanks again
Old 04-28-14, 06:47 PM
If you had an ammeter you could check the current draw of the circuit to see if it's routinely approaching 40va. You can certainly install the 50va transformer but if you have a wiring/short issue.... you'll pop that one too.
