How to clean blower fan?
Old 03-09-01, 01:10 PM
Guest
Angry
I have Gas Fired Furnace, High Efficiency Upflow GUG Series: GUG141A020. Snyder General Corporation; Model Number: U48A00.
My blower fan does not seem to turn as smoothly as before. When I turned the blower wheel by hand, I can hear slight noise and a little hesitation turning. Sometimes the blower fan does not turn on. It seems the furnace runs fine once the blower starts.
I opened the furnace and turn the blower by hand this morning, and it worked for a few hours and than stopped again.
Do I need to clean the blower motor or the blower section? If yes, how do I clean it? Do I need to unplug everything, take it out and clean with Warm water?
Is it possible that the blower motor is bad or the blower wheel might be bad?
The blower motor is:
Manufacturer: FASCO, Mfg Part #: 7126-1470; Part#: 1069694.
what would the cost be for this blower motor? how much labor cost?
The blower wheel is:
Manufacturer: LAU, Mfg Part #D11.8 X 10.6A; part#:2120191.
what would the cost be for this? how much labor cost?
Thanks in advance.
Old 03-10-01, 05:15 AM
fjrachel
Your blower wheel is more than likely ok. Sounds as though the motor bearings are starting to cease. You can pull the motor and check for oiler ports and oil them. If there are no oiler ports, then it is a sealed bearing motor. Oilers or not, I would change the motor as the damage to the bearings has already been done and oiling would only be a temporary fix. Have you checked the run capacitor for the motor? A bad run cap would cause the hard starting symptom.
Never clean a motor or anything electrical with water. Blow out motor with high pressure air. You can clean the wheel though.
Old 03-12-01, 08:20 AM
Guest
How do I check a run capacitor? Where is it located?
I did oil the motor, but it fixed temporarily and the problem started again.
How much is the cost to replace the blower motor?
It seems like it would require special parts to open the motor so I probably could not do it my self.
Thanks again.
Old 03-12-01, 03:25 PM
fjrachel
You may or may not have a PSC motor(run cap), you may have shaded pole. Anyway your motor bearings are bad. Replace the motor. Call someone and ask. Pricing for heating and air conditioning service calls and parts are not universal standard.
Old 03-13-01, 06:27 AM
Guest
I had a Tech look yesterday. He said the bearings were OK in the motor, the capacitor was OK also. But, He said it seems like some electrical problem in the motor. He told me 225 for parts and labor (to replace the blower motor). Couple of other places said in the 275-300 range. Does that seem reasonable? Motor only is about 100 dollars.
My furnace is about 10 years old. How long does furnace normally last? When should I have to change the furnace?
Thanks.
Old 03-13-01, 02:20 PM
fjrachel
The price for a motor replacement is about right. Alot of hvac companies have gone to a base price thing. I've seen them over 50 years old. Depends on alot of variables as to how long they last. Put the motor in yourself and save a hundred bucks.
