Carlin 40200 stuck in lockout
Old 09-06-14, 12:10 PM
B
Hello,
I have a new carlin 40200 burner on my Boch 32E and it entered lockout mode while trying to bleed the system (Amber and Green lights illuminated)
I've tried everything and I cant get it reset, the instruction say hold for 20 seconds- I can stand there and hold it all day it doesnt do anything.
Anyone have any suggestion? It's brand new.
Old 09-06-14, 12:26 PM
firedawgsatx's Avatar
Received 12 Upvotes on 12 Posts
Try holding it down for only 2 seconds if it is only on lockout. If it is on lockout only the RED light should be on.
Old 09-06-14, 12:50 PM
B
Gave that a shot no luck - Amber and Green lights are lit on the motor panel.
Thermostat on the tank showing Power (green) and Call for Heat (Amber)
Old 09-06-14, 01:21 PM
I suggest you post your issue in the forum: Boilers - Home Heating Steam and Hot Water Systems - DoItYourself.com Community Forums
I am sure that NJTrooper or one of the other resident experts there will be able to assist you.
Old 09-06-14, 01:40 PM
B
Stupid Fix...
The electronic controller had separated and when I took it off i noticed. Popped it back together and the button was actually engaging and reset.
System bled, flame adjusted, and the hottest shower I've ever taken.
Thanks!
Old 09-06-14, 01:44 PM
Glad to hear you got it figured out and fixed.
