out of oil
Old 03-18-01, 06:01 AM
Guest
I have a oil forced air furnance and I let the tank run out of oil. Refilled and changed the oil filter. Removed the bleed plug and tried to restart furnance. Furnance turned on (4x's)but no oil every came into the pump.
Is there anything else I can do before I can the repair man?
Thanks in advance.
Craig Gallagher
Old 03-18-01, 07:17 AM
PDF
Check inlet
strainer on pump.When you loosened the bleed plug and started furnace did oil spurt out?PDF
Old 03-18-01, 07:43 PM
Guest
No, oil did not spirt out of the bleed plug hole when the furnace was tuned on.
Oil was poured into the bleed hole and it would run through the pump when the tube from the filter to the pump was removed. The furance would fire up when turned on when oil was poured in the bleed hole.
Old 03-18-01, 09:21 PM
Guest
Try disconnecting the line at the........
pump and getting oil to flow out of the line there, not a little flow, get a bucket and fill it half way at that line before reconnecting then run with bleed screw open till you get a flow.
