York Diamond 90 - Ignitor Tests Good But Does Not Light.
Old 09-22-14, 01:38 PM
The ignitor will not light. I tested it for continuity and if memory serves me it reads about 75 ohms.
An AC voltmeter connected to the plug coming from the PCB reads zero volts.
I hear relays click and motors run but no glow from the ignitor.
I had this problem the last 2 years. After sitting all summer I get the same problem. For some reason it seems to fix itself and start working.
Last year it started working when I disturbed the bundle of wires going to the PCB. And it worked properly all winter. That fix didn't work this year.
My gut feeling is that I have a bad relay contact. I don't want to buy a new PCB only to find out I have a bad sensor or something.
My questions are these: 1) Which relay supplies power to the ignitor? 2) What switches / sensors would prevent the ignitor relay from pulling?
Or better yet maybe this is a common problem and someone knows the exact fix.
And BTW I'm getting 4 flashes on the red LED
Thanks
Old 09-23-14, 06:19 PM
Grady's Avatar
Somewhere on the furnace, usually on the inside of the blower compartment door, should be a key to the blink code. If you can find it, please tell us what the 4 blink code is. Sometimes the key is on the board itself.
