Need to elevate furnace
Carrier Weather Maker Infinity Furnace was installed too low in such a way that there's not enough space to draw in enough air. Not to code. That's what a tech told me.
How would you lift this furnace? Or would you take it out and the put it back in once a new higher stand is built? Current space drawing air is 29" X 9". How do I know what is sufficient space?
There's also a dryer in the little room here. If I'm not mistaken the guy said that it's considered a fire hazard to be drawing air from the same room. Not sure though.
Here's 3 pics....
Here's 3 pics....
The URLs for your images are not correct. Photobucket is throwing 404s. If you have the pictures on your computer: http://www.doityourself.com/forum/li...rt-images.html
Hummm.... they're showing up on my computer
http://i1316.photobucket.com/albums/...ps7a795a0b.jpg
http://i1316.photobucket.com/albums/...ps31e5cdd5.jpg
http://i1316.photobucket.com/albums/...ps704aa791.jpg
Is that the only return air there is? Where is the furnace located? Are you having a problem with the furnace?
Yes. Only return. It's inside a closet which is inside a small hallway with the washer and dryer.
Furnace runs fine, although when I put a grill on there it made kind of a roaring noise. Tech said it needs to be elevated or create more air intake room in order to meet codes.
I don't see any code violations here, just a bad install. Probably 80% of all furnaces are in the same room as a dryer.
Before I move the furnace, I would see if you can cut in another return, either on one of the sides or back.
