Coleman Model 2960 T.H.E 90 furnace issue
Old 10-23-14, 05:27 AM
This is a dual-fuel heatpump-gas combo. I noticed this morning (first time temp low enough for the gas to come on) the heat pump started first, after a couple of minutes it stopped. I then heard the familiar hum of the gas furnace. It hummed for several minutes, so I opened the cover. No flame, no fans, just humming sound coming from the top of the unit. After a while, it shut off. The stat timer fired it back up after 3 minutes, gas unit fired up perfectly. It seems when it switches from the heat pump, it doesn't start (just hums). But after cycling off/on, it works. I'm thinking control module, what do you folks think?
Old 10-23-14, 03:21 PM
I think the real question here is why did the heat pump only run for a couple of minutes? What was the temp outside? Was it raining or fog?
Old 10-23-14, 05:58 PM
Temp was around 45, clear, dry. Not sure, usually around 45 or so it switches to gas. maybe it was right on the outdoor stat setting.
Old 10-24-14, 08:28 AM
Most heat pumps will be set at 30*. I let my heat pump run down to 15*.
