Goodman furnace CVC95 Won't ignite
Old 11-13-14, 12:58 PM
A
Installed a new Goodman furnace. The fan will only work in the "On" position on the thermostat. Even though the fan will run the ignitor does not light. Please help its cold.
Old 11-13-14, 01:02 PM
firedawgsatx's Avatar
Welcome to the forums!! Did you set up the thermostat to operate your system? What model thermostat do you have? One thing you can do to see if the furnace will come on is to turn off power to the furnace and remove the wires from the R and W terminals at the thermostat. Then twist those two wires together to see if the furnace will start up.
Are you sure that is the correct model number>
