Floor furnace will only turn to low or to high.
This floor furnace only has 2 settings. Low which leaves it about 80 degrees in the house or high which leaves it about 95 degrees in the house. When I put the "new" thermostat on 70 or all the way down to 55 it only takes the inside of the house to about 80. Also when I put the thermostat down to 55 it only takes the house to about 80. I just replaced the low voltage thermostat with a brand new thermostat. It's only a 2 wire thermostat and it is level. Help?
