Goodman furnace with 6 light blinks
I just moved in to my house 2 weeks ago and my furnace went out this morning, it is a goodman furnace model number gdh80703ax. We have no idea what to do we are first time home buyers. Can anybody walk me through how we might be able to fix this problem or how much it might cost for me to have some one else come out to do it. I am very clueless when it comes to this stuff but would like o start learning.
Welcome to the forum!! The two most common causes for a 6 flash code on your furnace is a tripped roll-out switch or a blown low voltage fuse on the control board. Have you tried to reset the system but turning off power for a few seconds and then turning it back on? Here is a link to an installation manual for your furnace that may provide some specific information:
http://johnstonesupply9.com/TechDocs...20IO%20Man.pdf
Do you have power at your thermostat?
Have you checked the control board to see if the low voltage fuse has blown? It will look like an automotive type blade fuse and is colored purple. Do you have a voltmeter to check voltages at the thermostat or control board?
It will be in the compartment where the blower is located. All of the wires will be going to it. The one in the photo I posted is only an example. Yours may be a different color. The fuse is normally located close to the connector that has 12 wires going into it.
Just to note,to future readers,simply checking the fuse by eye will indicate if it is blown or not,the attached image where that little link(looks like an s in bwtween the connectors) should be connected. If it is not,the fuse is blown,and there is usually a small black spot where it is broken.
