trane xb80 not working at all
#41
Hi
Today i could bought the transformer exactly same as the old one and i'm going to install it this evening , would you please let me know if there is anything important on the Installation instruction .
i'm worried to have it blown !!!
#42
The first thing I would do is to install an in-line fuse holder with a 5 amp fuse to protect the transformer. For installation of the transformer make sure power is off. Wiring replacement should be the same as the original.
#45
Hi
Today i bought something exactly same as this one but the only thing that i'm not sure is the wire spec , should it be same as the wire coming out of the transformer ? to which of the out coming wires
should it be connected ? can i detached the wires from it and connect the wire coming out from transformer instead of it ?
#46
The wiring diagram shows the original transformer has a red and blue wire connected to the low voltage side of the transformer. I would cut the red wire and splice the fuse holder between the two cut ends.
#47
Thanks ,
Should the wire in either sides of the fuse holder be same as this red wire? the wires in the 2 sides of the fuse holder i think are a little bit thicker than the red wire coming out of transformer
#49
I should thank firedawgsatx , you helped me a lot and i appreciate your help and time .
Finally i changed the transformer and i even kept the old limit switch , and it's working perfectly ,
Thanks again
Thanks again
