No part number for Bryant 310AAV high limit switch
Old 01-08-15, 08:53 PM
I'm told I need a new one as it is tripping too much.
I cannot find the part#. I have an 80% effic Bryant 310AAV024070ADJA unit. Series D.
Ideas? Are they standard?
Old 01-08-15, 09:01 PM
Received 479 Votes on 449 Posts
Why have you started a new thread for your furnace ?
Which limit stat is it.... the one that shuts the burner down and keeps the blower running ?
What kind of problem are you having ?
Old 01-08-15, 09:13 PM
I think it is this one.. yes?
Carrier Amp Bryant HH18HA502 Limit Switch 180 | eBay
Old 01-08-15, 09:25 PM
actually I found the same one (same pic) on ebay. L180..
Carrier Bryant HH18HA502 Limit Switch 180 | eBay
So its a 180F limit I believe
Old 01-08-15, 09:39 PM
That doesn't appear to be the correct part. In the link below is a direct match based on your actual model number. I'm questioning which part is correct. This part I've located is a 165 limit while the one you located is 180
Bryant Furnace Limit Switch HH18HA499 Order now for same day shipping. 365 day return policy. Repair Clinic
Who told you it needed replacement ?
Have you checked the filters ?
Have you checked to make sure the returns are not blocked and not too many registers are closed down ?
Many people have changed limit switches to find out the problem remains.
Old 01-09-15, 07:35 AM
I had a service call yesterday.. I had a new filter which was probably too dense and the unit kept tripping (the high limit switch would lock open). It has likely been happening for some time. We put a lighter filter in and the hi limit switch still tripped again after a few minutes. It was locked open.
He gave the switch a tap with a screwdriver and it clicked and the unit went on.. then after a few minutes it stopped.
Leaving the filter out it did not lock.
He did check all of the returns.. open and clear.
He suggested I get a commercial low screen filter, and replace the hi limit switch which may be worn out.
From the picture alone I thought it was an H180, but you are correct from your link. I'll give yours a shot. I will recheck the manual to see what the hi limit temp should lockout at, but it never hurts to use a lower temp.. should never get to 165 anyways.
For $12 its an easy thing to try out, to see if it fixes the issue.
Old 01-15-15, 11:53 AM
I put in a lighter filter and the unit has worked fine since. I did get a new switch but I will hold off on replacing it unless the unit trips again.
