Pressure switch closed trouble code
#41
Awesome thanks! where do I place the black and red leads? on the pressure switch circuit? Do I disconnect the wires or leave the wire connected on the pressure switch when placing the black and red leads?
#42
i have 24 volts to the pressure switch. the 24 volts comes on of just a sec. Its funnny because sometime I see the 3 blinking lights and other times it don't blink at all when its running.
#43
I got it working now...I think one of the wires were loose...because the furnace will always keep shutting off by it self and every time I touched that wire the furnace will click back on. I tighten that wire and it seem to be working fine now. Hope that was the issue. But not sure why did the board giving me 3 blinks if the wire was the issue?
#45
Yes I already put in a new plug. Thanks! =)
This was a good experiences because now I know a little more about my furnace. Thanks to everyone that commented and helping me out.
#47
okay this is acting up again. The furnace comes on for about 30 mins then it shut off before temperature being reached...maybe debris must be in the inducer? the temperature rod and filter are clean
