Maintenance on a new gas furnace
Old 01-26-15, 10:35 AM
Jig
Jig is offline
Hi all,
I've just had a brand new gas furnace put in. In terms of maintenance, I know to have year or bi-yearly maintenance performed on it to maintain its life but what about after a new one is installed...does that still need to happen from year one or should I wait depending on labour and parts warranty?
Cheers!
Old 01-26-15, 03:56 PM
Grady's Avatar
Received 39 Upvotes on 37 Posts
With a new piece of equipment, I prefer to check it after the first season then every couple of years is usually plenty. Read your warranty carefully. Some require annual maintenance.
Old 01-29-15, 07:44 PM
Jig
Jig is offline
Thanks.
Do you have any knowledge about whether the furnace should control the 2 stages on a furnace vs the thermostat? I've read that the thermostat should control it as it reduces wear on the furnace's electronics.
Old 01-29-15, 07:59 PM
Beachboy's Avatar
Received 1 Upvote on 1 Post
Ideally, the thermostat should control the second stage of the furnace, for optimal heating comfort. However, to do so requires a two stage thermostat, plus an extra conductor (wire) in the thermostat cable to the furnace. If you don't mind paying for a new thermostat and running an additional wire between the thermostat and furnace, then you've have the true benefits of two stage heating. Depending on how your house is built, running an additional wire (if it's not already present in your current cable) may be cost prohibitive.
It sounds like your new two stage furnace is set up to fire the second stage based on an internal timer on the furnace's control board. For example, after your furnace has run for 15 minutes, if the thermostat hasn't been satisfied yet, the furnace will automatically kick up to second stage. That's not as ideal an arrangement as controlling the second stage from the thermostat, but it will NOT put any additional wear on your furnace's electronics.
If you're happy with the way the two stage option works now, then don't worry about it, it's fine. Otherwise, if you want to invest in installing a two stage 'stat, that would give you optimal comfort control.
Old 01-29-15, 08:13 PM
Houston204's Avatar
Received 75 Upvotes on 68 Posts
I would verify that your 2 stage furnace supports a 2 stage thermostat before picking up a new stat.
I know Goodman has a GMH95 2 stage furnace that does not support a 2 stage stat.
http://www.goodmanmfg.com/portals/0/pdf/ss/ss-gmh95.pdf
Old 01-30-15, 10:18 PM
user 10's Avatar
Received 50 Upvotes on 44 Posts
^The gmh is a piece of crap and the engineers at goodman should be ashamed of themselves for using a single speed inducer and no W2 terminal on the board. Best to lock that model on high fire to get the correct fuel to air ratio.
Old 02-02-15, 07:23 AM
Jig
Jig is offline
Thanks everyone. I have a nest thermostat which does support a 2 stage furnace. I do have an extra wire for this but I will need to verify if that wire is connected to the furnace and also if it is connected to the correct terminal for correct usage.
Nest has said that they will help me with the wiring so we shall see how that goes.
Thanks for the advice!
