Best way to seal unused chimney
Old 01-30-15, 01:28 PM
W
Received 1 Upvote on 1 Post
i no longer use my fireplace whats the best way to seal my chimney on the roof?
Old 01-30-15, 01:59 PM
Received 740 Upvotes on 646 Posts
Probably a metal cap but it somewhat depends on how the chimney was built.
Old 01-30-15, 02:30 PM
P
Received 1,764 Upvotes on 1,577 Posts
I form up a metal cap and use construction adhesive to glue it in place so the wind can't blow it off.
Old 01-30-15, 05:32 PM
Grady's Avatar
Received 39 Upvotes on 37 Posts
Like Pilot Dane, I use metal (stainless steel or aluminum), and glue with silicone & screw it to the chimney top.
Old 02-05-15, 04:02 PM
G
Received 25 Upvotes on 24 Posts
There are internet sites that fabricate custom-sized chimney caps. Mine has a solid lid to keep out rain and a surrounding stainless steel or galvanized grill to keep out animals. I'm sure they could make one that is blanked off, but someone needs to go up on the roof and measure the chimney, allowing a tolerance for fitting. Then fasten the vertical walls of the cap to the chimney.
You will need a cap that drains water to the edges of the cap and outside the chimney.
I take it just shutting the fireplace damper doesn't do it for you?
Old 03-17-15, 03:34 PM
W
Currently it has a b vent. I wanted something more for air sealing but someone said that it should have air flow for moisture etc??
Old 03-18-15, 07:45 AM
Grady's Avatar
Do you really want that cold air coming into the house? I know I certainly don't. The only exception would be if the house were extremely tight & you need that outside air for combustion/ventilation.
Old 03-18-15, 07:52 AM
While moisture in the chimney isn't ideal, since it won't be used - there shouldn't be much moisture and as Grady said, eliminating a draft is better than allowing a small amount of moisture. Unless the chimney has rain soaking thru the brick [and then you have bigger problems] I don't think it will be an issue.
