Lennox blower motor
Old 02-07-15, 05:17 PM
K
Lennox blower motor
I have a Lennox G40UH-48B-090-02 blower motor which sounds like it needs to replaced (Excessive noise and vibration).
It is mounted horizontally so that when I remove the front panels, the inlet and motor are on the right.
I have no idea how to remove this motor. I have loosened the screws to the electronics panel so I can slide that off the screws and hangs loose. I can see inside that the motor seems to be on rails. As the installation is horizontal, one rail is above the other.
The only screws I can see which might hold it in place are so inaccessible that it seems improbable. If I can get them out...getting them back in with the new motor may be a different issue.
I have checked to see if there are other panels which can be removed but there aren't.
I saw one video where two retaining screws towards the front held the rails in place but I have no such screws.
Anyone have some tips ?
Thanks in advance.
Old 02-07-15, 06:36 PM
Grady's Avatar
Some pictures of the blower & blower compartment might help us help you with removal.
Old 02-07-15, 10:44 PM
Houston204's Avatar
I would expect to remove the red screw on each side of the control box to gain access to the blower and then remove 2 screws highlighted yellow to slide out the blower if you have the furnace in this picture...
Name:  Lennox furnace.jpg
Old 02-08-15, 04:30 PM
Grady's Avatar
Once you get the control panel out of the way, blower removal should be easy.
Old 02-12-15, 05:49 PM
user 10's Avatar
Usually you need a socket set to remove the screws.
